Proscan connection
buddrousa
What type Scanner?
996p2 Close the Proscan Program and Power Cycle the Scanner after the scanner reboots restart PROSCAN.
536 Power Cycle the scanner and look at the DHCP settings in the router and if you can reserve the IP Address for the scanner or make the address STATIC.
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
OP's previous posts mention a 325p2. Close Proscan & restart scanner as suggested above. Reopen Proscan and try connecting again. If no improvement, restart computer. Good basic troubleshooting steps to try
ProScan
Software Provider
Ontario, Calif.
When I connect to the computer it wont connect to the trunk tracker v . It was working till I woke up this morning . It will not connect .
Whenever stating a problem, at least provide the scanner type and what you have done to try to fix it.
Is it working now? What did you do to fix the problem?
FrensicPic
Los Angeles
Also just un-plug and re-plug the USB cable and then use Comm Port - Auto Detect again. I do that often with my 996P2.
