Audio suddenly quit working for ProScan. I have read many threads and tried all suggestions with no luck as well as trying all of the ProScan check items on the URL Audio Setup & Monitor Tab If audio does not want to connect. I am thinking it may be a setting on my router, as under the URL Audio Setup & Monitor Tab the TCP Scanner Port 554 Time Elapsed stays at 00:00:00. I have checked all the Audio Control Tabs and all are set to URL and the URL Setup is not flashing red and shows the proper Scanner URL. I have also ensured the Loopback checkbox is checked under the Monitor & Test Tab. Any suggestions would be appreciated. Thanks in advance.
