proscan - custom filename formatting
pkneeyahx
Human
Almonte, Ontario
was there a change recently in a proscan update tot he custom filename formatting for recordings? I can't seem to get 24 hour time on my filenames. Its inserting AM / PM, which sucks for sorting files by filename in winamp, etc.
here is an example of what i'm looking to implement;
03-26-17 22-17-44 - Kinburn - 2OPS01 Arnprior.mp3
And when I try to use the %H formatter, it literally just uses the hour. not the entire 24 hour timestamp.
thanks!
ProScan
Software Provider
Ontario, Calif.
That's how the "%H" is suppose to work. &H = Hour (24)
What Custom Formatter are you using to give AM / PM. "%DT"? Checking the "24 Hour Time" option should do it.
{edit} Use this "%D %TT" for the desired results.
pkneeyahx
Human
Almonte, Ontario
I must have missed the "24 Hour Time" check box under the Options/General tab. I'll let you know how that works once the clock rolls over to 1300.
pkneeyahx
Human
Almonte, Ontario
Hey, thanks for reminding me about the 24 hour time check box. Its working.
05-13-17 - 09-56-38 - Kinburn - OPP Combined - 2OPS42 Renfrew.mp3
