I used to run ProScan with a Uniden BCD536HP and display the scanner on my PC monitors.
When using the "Display Only-Sizable" it would work appropriately.
Now, I've switched to an SDS200. If I choose the sizable option, ProScan would not show the entire area of the scanner's display.
It is as if it is being blown up.
Using the scroll wheel of the mouse to resize it and try to make it fit with the monitor display, narrows it until it looks elongated, portrait mode like.
This the first time I've experienced this with ProScan.
Not sure if it is a setting issue.
