ProScan Hit counter reset
Seymourmtn
Seymour, Tn
Greetings all
Trying to reset Log Hit Counter to zero. Click and nothing happens. Have tried highlighting single and all rows and still no luck.
Any thoughts?
Thsnks
Doug
kibler
Hello,,,,,,,,,,,In the past as I remember, the reset won't take place until a same Frequency is logged the next time again! In other words it resets each frequency one at a time! or Hi-light a part of or all and it will reset one at a time! Thanks
W4KRR
Coconut Creek, FL
I'm having the same issue. Seems to me if you reset the hits, they should return to zero immediately.
ProScan
Software Provider
Ontario, Calif.
That's by designed. The Hits counters doesn't reset the hits already logged. It has always been that way. No work was done in this area for years.
dodgerboi84
Tucson, AZ
Hits
I know this is probably answered somewhere else, however I was wondering what are HITS? I see it on my ProScan.. I know it's a newbie question.. Thanks
hiegtx
Dallas, TX
If you're running logging via ProScan. "hits" are the number of times the scanner has found and monitored transmissions on a specific frequency or talkgroup. There is a setting under options to disregard transmissions of less than 2 seconds. That eliminates recording hits when nothing of any substance was received.
The more hits logged, the busier a given channel (conventional or trunked system talkgroup) is. It's particularly useful in determining whether a newly licensed frequency, or new, unidentified talkgroup, is being used.
