ProScan - Maximum Connections
W6BAR
Hello everyone,
I finally set up ProScan with a BCD536HP and having a blast with the web server and scanner over IP features after spending some time getting it dialed up. I can now access/ control my scanner from my phone over LTE anywhere - which is great.
I ended up sharing my link a few times with friends to listen and do some experimenting. Even though I've sent the maximum amount of connections to 15-20, I can't seem to have more than two or three active listeners at a time before it shuts everyone out and I'm not able to regain access to it without restarting the feed. I realize this is not a ProScan issue and most likely some sort of IP issue. I was just curious, does anyone have any experience with tweaking their router or computer settings to help increase the amount/ reliability of external connections? For technical details, I'm running ProScan on a few-year-old laptop, directly connected to an ATT router with fiber.
Thanks everyone!
dave3825
Suffolk County NY
Who is your isp and can you get into your router's settings?
I am not an expert but if you have to restart the feed, it may be a Proscan issue. What version are you on?
