Proscan - multiple radios/2 computers
K3JTP
BALTIMORE, MD
Presently using Freescan on BCD396T and Sentinel for BCD436HP. Recently obtained BR330T and BCD325P2 and may replace Whistler desktop with a BCD536HP. A.-Can I purchase 1 Proscan account ($50) and set up a separate programming data file for each radio; B.- Does RR and Proscan support HF frequency programming for the 330T wideband coverage; C.- Will 1 account be available on 2 computers; finally, D - the laptop is Windows10, the desktop is Windows 7 (prefer the older computer for the serial port for 396T and 330T programming cable). Will the latest version Proscan work on W7? Many thanks.
Les
K3JTP
hiegtx
Dallas, TX
Les
K3JTP
You can install ProScan on up to two PCs.
However, you can run multiple instances of ProScan on a single PC. Just copy all the contents of ProScan's program folder on the PC to a separate folder & run it there. You can have multiple instances on the same PC, just as long as each is being run from it's own folder/ ProScan works fine on Windows 7, and Windows 10 for that matter.
I don't recall seeing HF frequencies in the database, but then I've never looked for them, even though I do have a 330T in my 'bone-pile' of unused scanners.
Whiskey3JMC
Avid surfer...of the AIRWAVES!
Montco, PA, USA
Les
K3JTP
A. Yes, though you'll need to store the programming files in separate folders
B. Pretty sure it will, never owned a 330T but the website says it is supported. RR database doesn't feature HF so you'll need to enter them manually
C. Yes you can sign into your RR user account on both computers
D. Directly from the website:
GTR8000
NY/NJ Database Guy
BEE00
The latest version, currently 17.8, will run on Windows 7 SP 1. Do not bother with version 17.0 as posted above...that is provided only for those still running XP.
