ProScan Not Showing All Systems In Quick Keys / Search Keys Tab
CanesFan95
Was Homeboys-Scanna
Banned
FL
I have like 25 systems programmed, but the drop-down list in the middle titled "Group Quick Key Status" only shows like 12 of those systems. Why? I want to tell it what Quick Keys should be turned on by default after you write to the scanner. But I can't get to all the systems cos they're not all in the drop-down list.
CanesFan95
Was Homeboys-Scanna
Banned
FL
I think that's how you tell it what systems should be scanned on power up. But I wanna tell it what groups (scanlists) within each system to scan at startup (or when you turn on a system for scanning). I have quick keys assigned to all groups in every system.
CanesFan95
Was Homeboys-Scanna
Banned
FL
And actually, the left column is confusing because of how it repeats the Site Name for quick keys that correspond to sites within that system, but not the system itself.
I guess I'm just trying to figure out why the middle column drop-down doesn't list all the systems that I have programmed. So, how do I tell it what quick keys to default on?
CanesFan95
Was Homeboys-Scanna
Banned
FL
See, notice how the system called "Hillsbrgh EDACS" isn't in the drop-down list. This is just 1 example.
ProScan
Software Provider
Ontario, Calif.
You may have to download from the scanner to ProScan to sync up first. Choose the option Download Configuration
CanesFan95
Was Homeboys-Scanna
Banned
FL
Aha! It looks like that worked. Thanks.
Say, what's the difference if I choose Off(*) or Not Assigned(-)?
ProScan
Software Provider
Ontario, Calif.
Not Assigned(-) indicates the number isn't set in any Systems, Sites, Custom Searches, & Service Searches.
Off indicates the number is set and the SQK is off.
CanesFan95
Was Homeboys-Scanna
Banned
FL
But it looks like it lets you choose Not Assigned(-) even if something does have a quick key assigned to it.
