2manyradioz
- Joined
- Feb 14, 2007
- Messages
- 27
Has anyone successfully run ProScan in Virtualbox?
I run Windows 10 on a Linux system and am trying to get Proscan to talk to my SDS100 and 200 using the USB connections. Proscan works great on the 200 with an IP connection, but neither scanner seems to communicate with a serial connection.
The USB cables and ports work fine; I can upload and download FL's to both scanners in mass storage mode. In ProScan, when I select the port (i.e 4) and then 'set', the bottom of the main screen shows the port being opened and the baud rate but the screen is blank. None of the radio buttons do anything. No error messages either.
Anybody have suggestions?
