ProScan - Quirky Logging
Omega-TI
Ω
Washington State
I upgraded my ProScan today and noticed something peculiar, on the history logging, I have it setup for one line per frequency, and on the non-P25 frequencies that's what happens, but as you can see here, the P-25 frequency of the WSP has two lines for the exact same thing. Anyone know why?
ProScan
Software Provider
Ontario, Calif.
Do you have another system "WSP (Local)" duplicating the same frequency and NAC? You can monitor the data arriving from the scanner to help determine where the problem is. Go to the Options - General tab then check the Scanner Data To Scanner Data.txt File option.
Omega-TI
Ω
Washington State
Thanks. My radio is a hot mess ( I should probably wipe it and start over), anyway after moving I've been tweaking things and removing a ton of stuff, I guess a dupe snuck in. Thanks for having such sharp eye! I'll take care of it.
Omega-TI
Ω
Washington State
Well, no, not the exact same thing; one has a System/Site of Cowitz, the other WSP District. You have a duplicate somewhere, find it and fix it.
It's a weird one, after the program is running for a few hours, the one changes to "Link" from P25...
... anyway after to work tomorrow I'm going to wipe it, "like with a cloth or something", ;) and start over.
ProScan
Software Provider
Ontario, Calif.
The scanner is sending that. Like I said in post 2, You can monitor the data arriving from the scanner to help determine where the problem is. Go to the Options - General tab then check the "Scanner Data To Scanner Data.txt File" option.
After any abnormality, view the "Scanner Data.txt" file with a text editor and see for yourself.
