What OS are you running?
Windows 10
Windows 8
Windows 7
Windows XP
Windows 10
Windows 8
Windows 7
Windows XP
Turned on the scanner this morning, and a firmware update was done. Also downloaded proscan update, and it is working now.
I can access the webserver from an outside ip address, but cant connect from my internal one for some reason. Also trying to figure out the audio delayed from the display
Try using the internal IP address. My router does the exact same thing. Outside the local network works fine but, on the local network I have to use the IP from whatever computer is running Proscan.Turned on the scanner this morning, and a firmware update was done. Also downloaded proscan update, and it is working now.
