Proscan - SDS200 Programing
vince48
Central Valley, CA.
Greetings,
I just received my SDS200 and I have set it up using "url". I'm runging and able to open and scan on my other PC on my Lan. Question, can I and how do I progam it while in "url" mode or connection?
Quite a learning curve about as complex as my Unication G5 (which is about to go "for sale"). Thanks in advance.
vince48
dave3825
rebmeM evitcA
Suffolk County NY
In Proscan Favorites editor, choose FTP Scanner Read and it will read. Then Choose FTP Scanner Write, and it will write your programming.
vince48
Central Valley, CA.
thank you dave ,
but this doesn't seem to work. Let me be clear, my SDS200 is in another room, and I am connecting to it via "url" mode, which is connection through my Lan.
I can't get the SDS200 to go into "mass storage" mode.
KevinC
OBT Matters
Super Moderator
Home
thank you dave ,
You don't need MSM when connected via the LAN.
vince48
Central Valley, CA.
ok, then what an i doing wrong? If I try to write to the in favoritew editor, i get a screen that says "select scanner" but it is blank. At the bottom of the screen, it says "send MSM command to scanner"
ProScan
Software Provider
Ontario, Calif.
Did you setup the scanner FTP settings?
Go to Settings - LAN Settings - Set FTP Server
Don't use the same User Name for Read Only and Writeable.
dave3825
rebmeM evitcA
Suffolk County NY
Using FTP Scanner Read, are you able to read the scanner? Did you set up username and password when you configured the url stuff in the scanner?
When you select FTP Scanner Read, you should be greeted with this
vince48
Central Valley, CA.
yes, i figured it out and was able to get the read working but got an error with the write. Where is this in the manual?
ProScan
Software Provider
Ontario, Calif.
Are you still getting an error when you try to write? If so then make sure the read only username is not the same as the writable.
vince48
Central Valley, CA.
no, i have that problem sloved, but now the stupid Close Call is the only thing being monitored, how the name of god do you SHUT OFF close call?
