Proscan truncating freqs?
nessnet
Kenmore, WA
Hi Bob,
On my 700 systems, Proscan is not showing/importing the last couple of digits. For example: Both WSP and WADOT have gone to a 700Mhz system, with freqs such as 770.83125. However, Proscan will only import 770.18312.
Is there somewhere in settings that I can change this to get all of the digits? Or, Bob, can you tweak Proscan to include more digits in the import?
ProScan
Software Provider
Ontario, Calif.
Hi Bob,
What type of scanner?
{edit} Can you provide the RRDB link you are importing from.
hiegtx
Dallas, TX
I would note that, even if you enter all five numbers past the decimal point, Sentinel will only display the frequency to the fourth decimal place. That's also the way they are stored in the main database- only four numbers, not five, after the decimal.
ProScan
Software Provider
Ontario, Calif.
Hi Bob,
I see a problem. 770.83125 is importing as 770.831200. It will be fixed in the next release.
ProScan
Software Provider
Ontario, Calif.
I tested this with a SDS200. In ProScan, wrote 770.831255 to the scanner then the scanner edit site shows 770.831250.
ProScan
Software Provider
Ontario, Calif.
Hi Bob,
I don't mean to be rude but please don't double post. Just send it via web report or email but not both.
I would have sent the fix to you today. Here are the bug reporting and suggestions guidelines.
ProScan
Software Provider
Ontario, Calif.
Hi Bob,
Nothing can be done in ProScan. The RRDB Web Service imports only the 1st four decimal places.
{edit} The 5th decimal place represents 50 Hz that is within tolerance so it wouldn't matter anyways.
