Proscan with 2 radios
nyair1
I'm finally getting my bc15x setup and was wondering how do i run this along with my 780xlt on one computer? I would like to be able to get the audio recorded from both radios. Do i have to get a second audio card for my laptop? I currently have the 780xlt running on proscan without any problems. I would like to split up the freqs in it and put half in my bc15x. Did some searching around but not much luck. Thanks
RonnieUSA
Rowan County,KY (Morehead)
I'm sure you Can't put a second audio card in a laptop.
NYRHKY94
Brunswick County, NC
nyair1
You will indeed need a second sound card to set-up each scanner with Proscan the way you intend. If the laptop is the the PC you want to use for both scanners, then you can add an external USB sound card. One scanner would run through that and the other through the internal on-board sound card.
Thanks - Mike
dcr_inc
Not an EXPERT !!
Delta, Pa
You can add a Second, Third and if you have a USB port, Fourth audio card to your laptop.. Look on Ebay for the USB audio adapters.. They are about $2.00 with shipping..They plug into the USB ports and have In and Output jacks on them.. They work great !!
nyair1
I will check into this. Thanks for the info guys.
Radio_RADIO
Winchester Ontario
Instead of adding another sound card your could make the sound stereo and use the left for 1 scanner and the right for the other.
You would need a 1/8 stereo cable to RCA then add to adapters to make the RCA connectors mono 1/8.
Plug the stereo 1/8 in the sound card and the the 2 ends into each scanner.
ProScan
Software Provider
Ontario, Calif.
Another way and the way I prefer is the same as above except change the audio mode to Mono.
