Proscan
sspo10
BYFIELD MA
Proscan I like the 5.2 program, works well with my 2 scanners. Thanks again
copmedic
Norwalk, CT
Can't get proscan 5.2 to work
I have the com port and scanner is being seen by proscan but when I try to connect to radio reference database through proscan it accepts my login but reports its unable to connect to the remote server at NuSOAP: RRWsdl.
I've tried getting it to work without my firewall and antivirus software. Can't figure this one out
mancow
N.E. Kansas
5.2 is rock solid. It's the most capable and the most bang for your buck of anything out there in my opinion. I've had remote setups running for months and you can't shake them, not a single error or hiccup. Support is nearly instantaneous.
If versions were made for transceivers and other scanner brands I would be broke.
ProScan
Software Provider
Ontario, Calif.
Are you clicking on the Database menu and Import menu? Don't use the Source Client as that's for streaming, not RR database import.
