Protest prep northern Minnesota?
KE0VUL
EN27
Heard on MN ARMER Polk EOC wanted NW 2 patched to NE 2. Also lots of chatter from surrounding counties about training for the past couple of days. Seems like their preparing for the worst with the Trump team in Bemidji and the Biden rally in Duluth tomorrow. Be interesting to see what the result is. It’d also be nice if we had a working feed off the Bemidji sites.
@KE0VUL this would better be discussed in the Minnesota Forum as it has nothing to do with general scanning, and especially since it mentions you wishing there was a feed from there. Though most traffic will be on TAC channels which are not allowed to be broadcast on the RR feed
KE0VUL
EN27
I'm assuming they won't use ARMER (State Radio System) for event tac/security..probably conventional to alleviate the towers since they'll be near each other. I'd also assume they'll go encrypted. The dispatch center will be probably using the main un-encrypted channels as routine. I do think they've upped the power today on some of the P25 sites though, unless 800mhz is ducting? Tac is allowed upload to calls though..
KE0VUL
EN27
Head Beltrami EMS did go to 8SOA2 as the event channel. Also heard instruction to turn radios off scan mode. Didn't go so not sure on Bemidji tower usage. Got traffic on DOT EC they started install of barriers at 8:00am sharp it sounded. With sweeps and securing of the area starting about 8 maybe a bit before. State Patrol started doing task assigning early around 5:40am. TRF and DL State Patrol dispatch were patched for almost the whole day. (Although normal at night anyway)
Heard State Patrol just drop STAC 5, STAC 11 was the reserved channel. Didn't sound like their was much that actually happened.
As of now Bemidji DOT is still doing the traffic control, major traffic congestion reported on BL-1. The surrounding ARMER sites are lighting up, probably the agencies are clear of all event channels back on scan mode. Seeing lots of random agencies using voice channels on Bagley, mostly BL-1 and EGF PD.
Anyone have any info from Duluth?
Could probably retitle this to, "Political rallies, 09/18/2020"
