ProVoice audio samples requested
rescue161
KE4FHH
Hubert, NC
Why do the digital radios have too be encrypted
They don't have to be encrypted. An agency will encrypt a digital radio because there is no deteriation of the signal on receiving radios. With analog radios, there was quite a bit of deteriation of the signal.
RiceCake
Thats actually incorrect, because the fact that it is digital is what fixes that. Unencrypted digital will sound identical on the receiving end as encrypted digital.
RiceCake
An agency will use digital radio because there is no deterioration of the signal on receiving radios,
they only use encryption to protect the signal from eavesdroppers.
But regardless, its just a minor clarification, so whatever.
rescue161
KE4FHH
Hubert, NC
Okay, I see that you must have missed my point. My point being: encryption with digital is better than with analog. Nothing more, nothing less. People would steer away from using DES over analog because of the signal deteriation. Not so with digital. So therefore, more users are using encryption with digital.
The using encryption to protect the signal from eavesdroppers is a moot point. Why else would they use it? They are using it more these days because it sounds better for the users and it's cheaper than ever before.
So, no clarification needed...
RiceCake
Yeah I apologize, its just anyone uninformed may assume that people are just moving to "encrypted" radio because it sounds better, which would make digital scanners a pointless purchase. Fortunately radio manufacturer's haven't tried to pimp that out or I'm sure every digital signal out there would be encrypted. Scanners are still hanging on!
Plus DES can't be used over analog. You need 1's and 0's. I suppose the only real encryption you can get over analog is voice inversion, and that's like locking a door with a twig.
Damn digital age is ruining everything.
rescue161
KE4FHH
Hubert, NC
DES has been used since the '70s over analog signals. I ran a contest here to see if anyone could break it. Only one came close. It's still up and running if you want to take a stab at it.
http://www.radioreference.com/forums/showthread.php?t=63775&highlight=des+contest
There is a lot to read through, but you'll find the files for your listening pleasure. Good luck cracking it! hehehe
Grog
Banned
West of Charlotte NC
I still get a chuckle out of all the know-it-alls saying it was too old and easy to crack :lol:
