Has anyone determined if the ProVoice, DMR, and NXDN upgrades work better on the BCD536HP or the SDS200? I'm considering purchasing all three upgrades but trying to decide which scanner to install them into.
A very good question and I have nxdn on both the SDS series end the x36.
Specifically it's an NX48 system in the 460 megahertz range with two sites in the next city over. Both sound good. No muddiness on either the SDS or 36. I use a rooftop so both come in well. On the Portables, using the remtronix 800/uhf the 436 definitely gets a better signal on both sites. By applying wide normal to both sites on the 100 it picks up well enough to decode the signal but there's a little more choppiness. The 436 doesn't miss a beat. Modulation wise the 100 sounds better.
As far as the 536 and the 200. Signal is the same and I do use wide normal on both sites on the 200. Modulation is better on the 200.
Hope that comparison helps. Overall my opinion would be both the SDS and the x36 work very well on that n x 48 system I monitor. My Whistler scanners do not work as they do not trunk track and there are many missed transmissions compared to the Unidens.
When I got the filters set after some playing with them my SDS200 has a little better range than my 536 but the 536 worked better with out changing the SDS200 filters. Hope this helps.
Thanks for your input. The main reason I ask is the scanner I put the upgrades in will be somewhat dedicated to DMR/NXDN (no ProVoice in my area). I'd rather tie up the 436 than the 200 with that duty.
Yes that is exactly what I would do. Use the x36 for the upgrades. Because of the SDR chip used, the SDS radios are slow scanners and take a little more time to cycle through the two sites I listen to. My understanding was the scanning speed was slowed down with a firmware update after release so as to improve overall performance.When I got the filters set after some playing with them my SDS200 has a little better range than my 536 but the 536 worked better with out changing the SDS200 filters. Hope this helps.
Do you have distant DMR NXDN and care to play with filters if not upgrade the 536.
The method that I use is Global filter first which is on normal which of course affects every object in the radio unless you go in to a specific site or into group options for conventional and change it. What I do is temporarily use Global filter and try wide normal, invert, wide invert... I never use Auto as it slows down scanning and you never know what filter did the trick anyway.
Yep easy process... Just to clarify that what I was explaining in that situation was nxdn system with two sites. If the system is all on one favorites list then you just monitor that favorites list. If there are other things on that favorites list then use system hold to isolate that system.If you hold on a frequency or system, how can you change the filter on demand? Is there a button combination to do so?
