ProVoice/OpenSky Question...
RadioDitch
Signals Identification Member
All over the map.
Have the opportunity to acquire my own P7250 for legit work purposes, but have a quick question for the experts before I make the jump also being ham/scanning enthusiast. The question is...
The radio, when properly programmed, should be able to receive an unencrypted, non-exclusive OpenSky and/or ProVoice system without a problem. Correct? Or would theI somehow need to be registered in that system?
For example...Middlesex County, NJ or the Pennsylvania State Police.
VE3RADIO
Planet Earth
Provoice yes... Opensky I believe has forced encryption.
greenthumb
Colorado DB Administrator
I could be wrong here, but a P7200 may need different code running on the radio for OpenSky and EDACS/Conventional/P25, so they may not be able to run concurrently on a radio.
FFPM571
Nashvillle
Opensky is IP based . Like every computer has an IP addres. If the system doesnt recognise the IP provided or the radio have the correct one from the system I wont work. Its like a system key.
at least that is how It was told to me.
RadioDitch
All over the map.
But is that for TX only or TX/RX?
FFPM571
Nashvillle
Before the radio is ready to do anything on the system it has to download a profile so if it doesnt have the correct information it will not validate the radio .When the radio is turned on it sends out the packet that its on the system. Once the radio recieves the informaton it will operate on the system the info has to match what the system has and then to validate it all. The users informantont is hardcoded in the radios themselves.
So if it doesnt recognise the radio it wont let it on the system and wont recieve.
Texas
The code is different, in that there are two separate code loads into the radio, one for EDACS/P25 and conventional, and one for OpenSky, but they can live in the radio concurrently, and you can switch between them.
As has been pointed out, unless an OpenSky radio is provisioned by the system, it can't listen, so you can't have an OPenSky scanner unless the radio is known to the system. P25 and EDACS - yep, that will work.
