Prpgrammer
abqscan
DataBase Administrator
Moderator
AOA
I just got me a new laptop and it has XP. When I try to read/write on programmer it freezes. Any clues on how to fix it?
Erik
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Eric, I'm not sure if this is what you are looking for but if so...
XP
This will solve instillation problems.
Control Panel,
Folder Options then select view tab.
Near the bottom, deselect the block "Hide file extensions for known files".
Make sure "Show hidden files and folders" is checked.
abqscan
Moderator
AOA
The program installed fine. Just won't read/write to my radio. I have another cpu that works fine and its XP.
Erik
fmon
Eclipse, Virginia
I guess you checked the com port. What program and radio are you using?
abqscan
Moderator
AOA
I'm using comm 1. I know it works because I can run etrunk just fine and program my 796d. I'm using an lpe-200. I'm gonna try a usb to serial.
Erik
you using a USB to serial conversion on the laptop? & on your desktop you have normal serial hookup.That correct?
abqscan
Moderator
AOA
My laptop has a serial port. It works fine on other software just not programmer. I tried the USB to serial converter for grins and it just says it can’t initialize the port. I can get the converter to work on other software on COM 4. I even got 13a programmer to see if that would fix the problem and it didn't. Its just not meant to be. I can even program other EDACS radios off the laptop with the serial jack. Kind of weird.
BANDIT
Gainesville, Ga
You might check on batlabs website. I think RSS and some of those programs require a slow pc and raw DOS.
No ProGrammer software works on any current model IBM PC,I have a 2.4Ghz processer & it works fine
