Prs600/performance On V-stars
TRON
How does the psr600 do on the VSTARS system? Can you use the extended frequency tables on the psr600 as you can on the pro96/2096 if using Winstar software?
Thanks for all assistance.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
If you mean Win500 software, yes. You can also set the tables using the scanner keyboard. However, if you set the system to P25 Auto, the tables are entered automatically by the programmed control frequency the first time it scans the system.
How does it do? If you load CPU U1.2 and DSP U1.2 STARS works perfectly.
TRON
Psr600 Vstars
Thanks for the info Frank. You've helped me before on Vstars and I appreciate it.
