Pruning a 440 antenna
I have several plans for 22 and 33 element beams for 440, out of the ARRL Antenna Book.
My question stems from a discussion I had at a recent ham club meeting.
Can I take plans for a 22 element 440 beam, and make just a 7 element out of it, by just using 5 directors instead of 20, without changing the original spacing or length of the remaining elements?
tyytor
Wyoming
W6KRU
Vista, CA
I don't think that would work very well at all. There are plenty of yagi calculators on the web. Here is a pretty good one. If you don't like it, google for more.
Martin E. Meserve - K7MEM - VHF/UHF Yagi Antenna Design
kb2vxa
Banned
Point Pleasant Beach, N.J.
The rule of thumb provided it's a true Yagi is all the directors are of the same length and spacing so just take it from there. You don't need a calculator, only a hacksaw.
K
kb0nly
Guest
My thoughts exactly.
I have taken designs for UHF that were 20+ elements and built a 10-11 element yagi using the dimensions for the first half of it, worked just fine.
k8wha
Lansdale, Pa
Theroetically the answer is yes.. the reality of the situation is not exactly... all those director elements have an interaction and the spacing makes a difference in the overall gain of the antenna. Going down to five disrectors with out changing the spacing slightly will not yeaild an optimized forward gain as well as Front to back ratio. Also the horozontal lobes are affected by wave length height. You may be better off just keeping the 22 elements and adjusting the height to pull the lobe angle higher since you will end up with reduced gain with 7 vs 22 or 33 elemnt yagi.
Something to think about...
73's
Dick
I made a 5 element
73's
Dick
Thanks for the help. I ended up making a 5 element from the links posted earlier. I had to go with a "shorty" because the antenna was going to have to be end mounted off a mast. I didn't need a whole lot of gain anyway, and all 440 machines in Metro Detroit are due north for me.
