When checking the rubber gaskets on the antennas on my F-150 (they dry out fast here in AZ!) I noticed one of the antenna mounts had become a bit loose. I was away from the house, but I do have a toolbox in the truck so I grabbed the large adjustable wrench and gave it a quick tighten. I didn't have a spanner to make sure the base of the mount stayed put when tightening down the nut but I went a head anyway, and as I was truing the wrench I didn't realize I was spinning the entire mount . Just a half turn was enough to mangle the coax connection at the base of the mount, pulling an inch or two on the cable that was secured to the ceiling with aluminum tape.
So I spent a Sunday before it gets brutally hot here pulling off all the body panels and getting above the headliner to install a new NMO mount and run the coax, following all the same steps I documented last time.
tl;dr right tool for the right job, etc..
