PSR-310 Question
kf4sek
Cocoa, FL
Is there a way to delete all talk-groups at once in a scan list on the PSR-310? Right now, I am deleting one by one and this is slow. I am not wanting to reset the unit. However, I saved a bunch of talk-groups to a scan list and now would like to delete them all in order to reorganize their order. Is there a way to do this, without software, or am I stuck with deleting one by one?
Thanks!
N8IAA
Fortunately, GA
Thanks!
If you are using Win500 to program the radio, click on Edit, click on Select all, click on Delete, say yes to all. It's done:)
HTH,
Larry
kf4sek
Cocoa, FL
Thank you for the response. However, I was wanting to do it manually and not using any software. I guess there is no way to do it. I thought there was a way to do it on the PSR-300 so I thought maybe that carried over to the 310.
Thanks again.
detroit780
Silent Key
Michigan
Psr-310
I don't have a PSR 310 but perhaps you can find your answer here?
Easier to Read PSR310/410 Scanner Manual search objects
Thanks!
rylvir
CA
I believe this is what you are looking for, pulled from the manual: (didn't see this section covered in the above link)
To delete a TSYS, use the FIND feature to search for the TSYS by name. Press PGM, then press the EDIT softkey, then press the FIND softkey, and use the Standard Text Entry Method to enter all or part of the TSYS name you wish to delete. Press the OK softkey to begin searching, and, if necessary, press the NEXT softkey to continue searching until the desired TSYS is located. Once the TSYS has been located, press the PGM key, then press FUNC CL. The scanner will ask you to confirm the delete command before removing the object from the scanner’s memory, then, provide a final warning that all TGRPs associated with the TSYS to be deleted will be lost if you proceed. Press the YES softkey at both warnings to delete the TSYS.
An alternative method is to browse TSYS objects only using the TSYS filter. Press PGM, then the EDIT softkey, then 444, and press the TSYS softkey. Scroll to the desired TSYS using the 56 keys, then press FUNC CL. The scanner will ask you to confirm the delete command before removing the object from the scanner's memory, then, provide a final warning that all TGRPs associated with the TSYS to be deleted will be lost if
