PSR-400 and rebanding
me
Could someone please help me with settng up a PSR-400 for rebanding? I am using the ARC300 software.
Thanks in advance
mikey60
Oakland County Michigan
Thanks in advance
Depending on the system you're trying to monitor, you may be out of luck until GRE can produce firmware to support rebanded systems. Please let us know which system you're trying to update, and we can tell you if it will work or not.
Mike
mikey60
The system is UCAN
Ok, Most of the UCAN sites are not able to be tracked currently by the PSR-400. Any frequencies between 851 and 854 with a 0 in the 4th decimal place will not be properly tracked at this point. GRE will need to put out a Firmware Update to correct this.
Mike
me
Ok, perhaps a little more specifie. Motorola Type 2
me
Mike
That's what I was afraid of. Thanks
