Hi folks,
I have a GRE PSR-500 I bought a couple of years ago. It didn't come with the USB cable (nor the CD), so after a year or so of programming by hand I decided to try to track down a cable. I managed to find one recently and have just been trying to get it all going, with my Win10 PC and ARC500 software.
Ok, so... I can't get drivers to install properly. I've tried the GRE ones (v1.11 and 1.3a) from the GRE website, the Radio-Shack one from the ScannerMaster website, and the FTDI one from the FTDIChip website. I was hoping at least *one* would work!
The first of these, and one with which I persisted longest, was the GRE 1.3a driver. What I find, is when I try to install (running it as administrator), it comes up with this:
Trying to install *subsequent times* does not give this error, but the driver appears to get installed *twice* for some reason:
Note: the installation procedure (little DOS window with '.' chars, only stays up for about 1 second, and only shows one or two dots... which I suspect is a bad sign.
Anyway, I plug in the scanner and turn it on, and fire up ARC500. I'm getting no sign of life, this being the best I can get:
I presume the grey horizontal bar in the middle is a progress bar... it just stays grey.
I've spent a good couple of hours, trying all drivers (uninstalling after each attempt), USB2 and USB3 ports, and have had no luck whatsoever.
I'm pretty sure the cable is the right one (RADIOSHACK TRS USB Programming Cable) so presume this is mainly/solely a driver issue.
Having gone through these forums and elsewhere I cannot seem to find anything obvious as to why this is happening.
Would anyone have any suggestions?
Thanks for reading!
Cheers,
Chris in Oz
Thanks for reading!
Cheers,
Chris in Oz
