ok heres the problem i had with this
http://www.radioreference.com/modules.php?name=RR&sid=556 system today. It's kinda complicated so bear with me, but most of you guys are smart (otherwise we wouldn't find interest in this hobby).
This system as you can see has three separate sites. Richmond, Henrico, and Chesterfield.
Richmond's PD etc is obviously broadcasted on Richmond's site
Henrico on Henrico's site
Chesterfield on Chesterfield's site
There several talkgroups, for example, Richmond PD Precinct 4, that are broadcasted on Richmond's site as well as Chesterfield's site. I've learned that this is because there is a Richmond unit on that TG near Chesterfield's site, therefore the TG becomes affiliated with it. I live in Chesterfield, so I can pick up Chesterfield's towers fine, but don't have as good reception of Richmond and Henrico (altho depending on where I am and antenna, usually can pick it up).
So I created a SYS in the 500 for Richmond, Henrico, and Chesterfield. I then have a separate scanlist for Richmond PD, Henrico PD, and Chesterfield PD.
If I set the system to ROAM, then the scanner (like it is supposed to) locks onto the strongest site (which is usually Chesterfield), however, if I want to hear Richmond's PD, I only hear the PD TG's that are affiliated with Chesterfield's site (since that is the only site the scanner is locked on to).
If I set the system to OFF, the scanner locks onto the first available site, therefore I'm only picking up the TG's affiliated with that site (like above).
So, it would make sense that in a system like this, setting it to STAT for stationary would make the most sense. That way the scanner uses all the available sites for that system. Therefore if I'm listening to Richmond PD, the scanner doesn't just use the close Chesterfield site, but will also search the more distant Richmond site for TGs. However, the problem I had is when listening to Chesterfield PD, the scanner would have a more difficult time noticing the active talkgroups. Also, when I was in Petersburg today, and had decent reception of Chesterfield's site (but none of Richmond or Henrico), the scanner would act like it couldn't find any available site (therefore no "T" in the display) while in SCAN mode. (my 396 was picking up the TGs). If I "analyzed" the site (control channel), I had a decent decode rate. Just in scan mode, it acted as if it had no reception. Setting the SYS back to ROAM, however, allowed it to lock onto the active Chesterfield site, and work much better.
So it sounds like there is some problems with the STAT mode actually recognizing all the sites or something.......
I wish there was something in between STAT and ROAM mode, that allowed it to use all available sites, but give priority to the strongest one, but that might be a different issue.
hope this makes sense... Andrew
