fmon
Silent Key Jan. 14, 2012
Don't find this "Noise Thresh"in Glob menu. However, Glob Atten: ON helps VA STARS (I pick up the Chesapeake tower also). Turn it off, only Hampton Tower is used. I lose distant CC of other trunking systems when Glob Atten is on.cpunut said:Here is one to try (more good info for GRE) for those of you-all that are having P25 system problems...
Try changing the "Noise Thresh" in the F-Glob menu to its maximum value of 128 (make sure to press F1:Save), and then re-test with supertrack on/off on the TSYS.
Hampton Tower is all that will function when Atten: ON is selected in VA STARS TSYS scan list.
