uP Boot Ver:F1.4
uP App Ver: NONE
CPU SW Upgrade
Waite for PC/IF This now what is on my screen.
Delete the update file on your computer and download it from GRE again in case it got corrupted.
Be sure you are downloading the correct file, and be sure to un-zip it before using it.
There are 2 updater files in the zip file. Read the PDF instructions there carefully to determine which one you should be using according to your scanner's Boot Version.
Start the process again - use the A/C power adaptor. Follow the instructions to the letter.
Be sure you know which com port your cable is using, and use the "Test" button at the start of the update process to be sure you are communicating with the scanner.
By the way, This is a quote from the instructions:
"Upgrading your scanner is a quick, simple and safe process. There is no way you can
render your scanner inoperable by performing the upgrade."
