PSR 500 Global Settings Win500
Ensnared
Waco, Texas
I've been making some adjustments to my PSR 500. These adjustments were found in the Easier to Read Guide. I can find some of these in Win500, but I cannot find TGRP Pri Int. Am I missing something?
ScannerSK
Weld County, Colorado
In the PSR-500 owner's manual (p. 102 in my edition) it states, "Toggles priority interrupt scanning during trunked calls". In other words you can set the scanner to interrupt trunked conversations in order to check priorities or leave it off to only check priorities when no trunked conversation is in progress.
Personally, I leave this set to off to prevent trunked conversations from being interrupted.
Shawn
lehigh4me
Lehigh, Iowa
In Win500 Ver 2.07 it is on the first page on the right side in the Priority Settings menu. It says TBRP's interrupted. I have mine checked since it is for WX Priority and I live in a tornado area.
ScannerSK
In Win500 Ver 2.07 it is on the first page on the right side in the Priority Settings menu. It says TGRP's interrupted. I have mine checked since it is for WX Priority and I live in a tornado area.
Just a heads up, this setting has no effect on WX-Priority. Whether TGRP Priority Interrupt is turned off or on WX-Priority functions the same.
Shawn
Ensnared
Waco, Texas
New Discovery Win500 2014
First of all, I was unaware that there was a newer version of Win500. I downloaded it today.
I looked at this setting on the first page; however, I thought it was related to WX and being interrupted for sampling of NOAA. I did not know this applied to other conventional frequencies.
Thanks for the help.
savage308
Belleville , ontario, canada
updated winn 500 to version 2.07, downloaded my file from scanner to win 500, but its saved as note pad it wont let me select winn 500 to open it with , if i left click on the note pad file then choose program to open it with win500 scanner utility pops up i click on the win utility and ok the file seems to open but in the winn 500 folder the file is still note pad not a winn 500 file, ??
lehigh4me
Lehigh, Iowa
savage, I don't know why it would save the file from scanner as notepad file. I would download from the scanner again and click file then click save as and make sure it is saved as .p500 file.
N1BHH
Jackson Square, East Weymouth, MA.
You must download the Win500 file and unzip it to the same directory you created for Win500. If not, create a new one. I use Big Speed Zipper to unzip files, because you can see better where to unzip the program, you can choose where you want it.
baayers
Pinellas County FL
It sounds like you have associated the .P500 extension with notepad. Here is how to fix this. With different windows versions the terms may change but the general idea is the same.
Make sure that your files has the extension of .p500
Right click the file your trying to open and select the open with menu and select choose program
Win500 will not be listed so click the browse button and navigate to the win500 application
Make sure the the always open with this application check box is check and say OK.
You should now have the .p500 extension linked to Win500
TES
America's High Plains
Win500 has a built-in method of associating .p500 files with Win500:
Configuration > Misc...
Press the P500 File Associate button and then click OK.
baayers
Pinellas County FL
You're 100% correct. I don't know why I always forget about that. I guess now that I've gone the long way I should just consider myself at least happy that it's associated correctly. LOL
