RodStrong, I changed a couple settings on my scanner, and it seems to have helped with this problem.
First I took the rechargeable batteries out and put in Alkaline. I run on the wall wart constantly here at the house anyway. The scanner stays much cooler. Then I set the Multisite mode to "stationary". It was set to "roam". I also adjusted the squelch to about 11 o'clock. So far it has continued to scan noninterrupted.
I have been emailing Jack at GRE technical support. The customer service GRE provides seems to be second to none!!!
I don't think my issue was related to settings on the radio or programming. That is only based on the fact that I have the exact same program in two Pro 197's that have worked flawlessly, and I rarely, if ever, mess with the settings.
As I mentioned before, I simply took the radio case off, separating the two main boards numerous times, and fiddling with the connection as I put them back together. I was trying to find something loose, out of order, etc. I saw nothing unusual.
When I had the problem, the scanner would not receive anything at all. I could hold a tranceiver right up to it on a selected frequency, and although the radio looked like it was working and scanning, it would not pick up a thing. No trunking data from my local system, no weather channel (very strong), nothing. It was almost like the receiving capabilities of the scanner went dormant, and would at times wake up and work normally. This problem developed weeks ago, and was come and go. It got progressively worse until it was having the problem at least half the time or more, and the scanner was starting to become totally unreliable.
I can only speculate when putting the boards back together I lined something up just right, or re-aligned something that wasn't right. I know that probably sounds silly, but the scanner is magically working perfectly again. Maybe just fingering the boards and taking them apart did something. Static buildup? I dunno. I wish I knew what I did. The scanner is in a scanner master soft leather case as well. Don't know if the scanner being wrapped up in a case for months and my opening things up and tearing it all apart made any difference or not either. You can probably tell I am struggling for an explanation.
I too dealt with the GRE guy named Jack, and he seemed very nice and genuinely concerned about helping me. I felt like I wasn't just an ordinary customer that couldn't figure out how to program his/her scanner. We had been emailing back and forth for a couple of days and we were just about to go over repair pricing when somehow I got it working. It's still hanging in there. Thanks again to all of you for a good discussion, and I hope we can all benefit if the problem I had occurs with others in the future.
