Hi, I was hoping someone could help me figure out a problem I've been having with my PSR-500. The scanner at times will not receive anything that I am scanning at all. Even though it shows to be scanning, it will simply not pick up anything. Other times it works perfectly. The problem just comes and goes. I have some p25 trunked stuff as well as some p25 simplex and analog. I believe it has all the latest updates.
The scanner will just stop picking up trunking data, and also won't receive conventional signals even if I hold a transmitter right up to it. Does not matter whether it is actually scanning or on manual mode. I use the same program in a couple of Pro 197s, which work fine, so I know it's not related to the programming.
Any ideas? Thanks.
Any ideas? Thanks.
