PSR-500 LCD Light
beischel
Pierce Township, Ohio
Are LEDs used to light the LCD display screen? I have it running on the power supply and the middle of the radio gets warm. Is the heat from the power supply/charging circuitry or is it from old fashioned light bulbs that light the display?
raisindot
Not being an electronics guy, but I'd have to say it's the power supply/recharger. The way you might want to test is to run it the same way on batteries alone and see if gets as warm. I can't imagine the backlights being THAT hot--can't be more than a couple watts at best...
Suzie
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
The 500 uses LEDs to light the display.
Probably heat being dissipated by the internal regulators. if you're charging the batteries at the same time, they're heating up, too.
beischel
That's what I thought, but wanted to be sure. I knew someone out there opened it and noticed what lit up the LCD display. Thanks.
