PSR-500 manual programming
WayneH
Forums Veteran
Your master site
The original question was how much could you manually program that you didn't need the software for.
As he said: the PRO-96 has features, such as the tables, that required the software as you could not access it via the scanner interface.
Is the PSR-500 fully programmable manually (by hand, no cable, no software) ?
skip39
Milford, PA
i am having some problems programming a 400 mhz trunked that is used by the otisville federal prison in orange county, new york. after programming the system i haven't been getting hits on the talkgroups for the system.
ryan
NDRADIONUT
FARGO ND
Do You Have The Base / Step/ Offset Business Set Right ?
Have You Listened To The Voice Channels To See If There Is Any Activity ?
Is There A Wildcard Group Present And Not Locked Out ?
