PSR-500 Multi TYS in 1 Scanlist Question
tglendye
I have a statewide system (Va STARS) that requires more than one TYS to capture all of the CC's in the system. I have placed 2 TYS's into a single scanlist and copied the TG's into both scanlists.
When it scans through the 1st TYS scanlist, it passes through the CC and then onto the 2nd TYS and looks for an active CC, causing a delay. I think there is a setting to eliminate or minimize the time on the 2nd TYS(and weaker) passing... but can someone tell me how?
Thanks,
Todd
jehm1212
Hanover County, VA
Make sure the dwell for each system is set to 0.
Side note: why do you have all the STARS CC's programmed at once? Surely you can't hear more that five at a time. I live in Richmond and only have a few sites in my STARS system. If I travel, I'll put more in.
tglendye
Sorry for the delay, I was gone for a couple of days and then had so much email I didn't see the response. Thanks for the info. I'll give that a try. I'm just kind of playing around w/ things. I was taking a "mini" trip and loaded all the CC's from the database.
Todd
