fmon
Silent Key Jan. 14, 2012
Has anyone with a PSR-500 had problems decoding Hampton P25 or ORION P25?
My 500 will not decode this system nor the ORION P25 system.
Programming is correct on both systems in fact, I cloned the in car din slot PSR-600 from the 500. The 600 works on both without any problems. As does 3 Pro-197's using same programming.
The 197's and 500 hooked to same scantenna using a 4 outlet amp box. All have 4 to 5 bars and all but the 500 have the T on display. The 600 also has 4 bars with the T.
On Analyz, the 197's on this antenna setup decode at 99% wit T while the 500 remains blank on bottom line. The 600 decodes low 90's to 99%.
All other systems work fine on the 500 including STARS and York, JCC P25 systems.
I've used ATT, taken the scanner on the road and still no T or decode info.
Got a ticket in with GRE this afternoon and they have replied twice and will send me an RMA if I ask.
