PSR 500 signal sweeper
bee
Belmont, Ms.
Does the signal sweeper work in the background, like it does on the 996t?
On the 996t, if it is stopped on a frequency, the close call does not interrupt the voice, on that frequncy. Is this the same with the PSR 500?
mikey60
Oakland County Michigan
If you create it as an object and add it to an enabled scan list, it will be scanned along with all of the other enabled objects. It will not interrupt a transmission in progress on another object.
Mike
