PSR 500 Software
M
missionmankind
Guest
Does any one know any EASY software to program the GRE PSR-500 with?
someone said a free program called Win500 is good...
Anyone here agree or disagree on that?
Im a complete nOOb to this scanners programming but nonetheless I wanted the best cheapest digital scanner out there so i went with it. Any help is appreciated! :)
N0WEF
Mpls, MN.
One thing to do is, try both free TRIALS from ARC and WIN, and see which one you feel most comfortable with.
Just a thought.
IredellMon
North Carolina
Just a thought.
This is pretty much the advice most people will give you, and its valid (along with advice to search the forums since you are the 10,272th person to as this question ;). It does not take too long to test drive them but if you don't have time I will make a suggestion since I used both PSREdit and Win500 for quite a while before deciding on Win500. PSREdit did a few things better, like importing from spreadsheets, but WIN500 allows you to make changes to things like lock-outs, delay, etc a little easier (at least the way i do things).
Win500 sold me with a feature that allows you to select channels to record then run the Monitor/Control function of the software and sit back and relax while only the transmissions on the channel(s) you choose to record are saved to the hard drive (in wav format). For example I leave the scanner and computer with WIN500 running all night recording the firecalls.. then in the morning I can listen to the transmissions with no dead air, and in minutes find out what happened overnight.. cool.
(It is a little flaky at time though, sometimes it won't record and I have not fully figured out why. For one thing it seems to need to be in scan mode, so if you want t monitor/record only one channel you need to set up at least one other that wont anything, or at least very little)
BTW is appears to me that PSREdit is being supported and updated more that WIN500. So far Win500 support is OK but who knows that the future holds.
And for the purist out there.. substitute the word object where needed.
N0WEF
Mpls, MN.
LMAO!! Nice :lol: Oh, and PSREdit also offers a free trial. (My apologies, for forgetting to mention that.)
rwier
Phoenix, AZ
............................................ used both PSREdit and Win500 for quite a while before deciding on Win500. .......................
Both still in use here. I switch back and forth just for the "back-up" results. I have spent countless hours "tweeking" Alpha Tags on both the 500 and 600. This is a long time ongoing process. I now see on the radio screens exactly what I want to see (for now) and it rarely looks anything like what came in originally from the RRDB. The more "save as" files that I have stashed around, the better.
Highpockets
Toms River, New Jersey
I'm lost on the comment about Win500 not being supported/updates and it's future. Why fix what's not broken, and the last I heard DonS was doing very well and I would say the future for Win500 looks good.
IredellMon
North Carolina
Of course now I can't find the comment that led me to that conclusion, so you're no doubt right. Just hope he's not into sky diving, bungee jumping, race car driving, etc.. ; )
