PSR 500 stuck
Srobo
New Whiteland, Indiana
I have a PSR500 that seems to be stuck. It says it is scanning but at the bottom it is stuck on the first conventional frequency. If I hit scan it will just move to the next conventional frequency. I ajust the squelch and it does nothing. I tried reloading from Win500 and nothing. Any Ideas?
ibagli
Ohio
Is only the 4th line stuck (do you see the scan list numbers) or does it show just like it would if it was receiving the frequency?
bubbaearle
Try this
Try taking the back off of the radio and making sure everything is plugged in securely.
Also look at the screw near the antenna......see pics
Srobo
Yes it is only the 4th line. It does not seem to be receiving anything though. I have another PSR500 that receives while I hear nothing on the stuck one.
bubbaearle
Which was it???
Thanks bubbaearle! That seemed to be the problem.
scott
Was it the screw or the connector between the boards?
A chunk of foam in there wouldn't hurt.
