PSR 500 Upload Question
misterdk
Philadelphia, PA
When I upload to the scanner using the ARC 500 software does the scanner have to be in a particular mode? Or can I be listening to it scan and upload at the same time? Thanks.
JoeyC
Senior Member
San Diego, CA
No, you cannot listen and upload at the same time, but uploading only takes about 20 seconds, if that. Its best if you start the upload after hitting PGM first, but it is not necessary. If you upload without pushing PGM first, you will get an error about every 5th upload that will require you to upload again.
