psr 600 6.25 in the 42 meg band
ICP114
how do i get the 6.25 split on it.. i tried prog glb and i could not find flex step
any help???
ICP114
i meant 482meg
i want to set the split to 6.25. FDNY will be in this mode soon.
spooney
Indiana
Did you update your firmware with the Feb. 20th updates? Flex Step was added and it is accessed in Extended Settings >Expert Settings< Press: PROG - FUNC - GLOB (F3) scroll down to: [FlexStep:] ON
You do not select a step number ie 6.25 Simply enter the freq and the scanner selects the step. When you save it and it doesn't register what you entered, it will select the next closest freq that the scanner is capable of receiving. 6.25 is working on my 600.
