PSR 600 Programming
walleye
Saskatchewan
Hi there,
I recently bought a PSR 600 and downlowded the PSREdit program.I am having difficulty programming the scanner.I would like to put Saskatchewan Provincewide APCO 25 system into the scanner,but I get the message nothing enabled after I tried to program it.I must be doing something wrong.Your help is appreciated!
smason
Alberta Canada, Eh!
I'm not familiar with PSRedit, but most programs are similar.
Nothing Enabled means that there are no scanlists (with objects) selected.
Are you assigning scanlists to objects?
Once you have uploaded it to the scanner, and you hit scan, press a key for one of your scanlists, and it should start scanning it.
skondolf
Hamlin NY (west of Rochester)
Walleye -
Go to the main list of forums and scroll down. You'll find a GRE Scanner forum as well as a Scanner Programming Software forum that you might want to post your question in - I might suggest the Scanner Programming Software forum. Many users of PSREdit can be found in there.
I, too, recently bought a PSR600. When you enter the info into PSREdit are you then uploading what you programmed from the software into the radio? Entering data into the software doesn't automatically update your radio.
Also there may be updated drivers you need to d/l and install in order to get the USB cable to work between your pc and radio.
Again, the Scanner Software forum is probably the place to check out.
