PSR-600 to TRX-2
Freqed
I'm just a listener
Broken Arrow
Having owned a PSR-600, even though it was made by GRECOM, does the TRX-2 support roaming the same way the PSR-600 does? With the PSR you could enter a system and TGID and while mobile you can lock onto a TGID and the radio would follow the needed sites to maintain that lock as you move around the area. Will the TRX-2 do the same? I know the Uniden with GPS turns on and off sites as you have them set-up but if you lock on an ID at one site it will not hold that lock into the next site as the PSR would do.
tvengr
Well Known Member
Baltimore County, MD
The TRX-2 also supports roaming. You need to setup separate sites on the TRX-2 rather than loading all of the control channels into the frequency list for the system on the PSR-600. One thing the TRX-2 lacks is the ability to scan several sites at once. It will only use the site with the best signal. It does not have the Multi-Site Stationary option like on the PSR-600. If you wish to scan several sites at once, you need to setup separate systems with each one using a different site.
gmclam
Fair Oaks, CA
Early on, I tried to migrate from a PSR-500 to a TRX-1. The short answer is: it was a big mistake. I later sold the TRX, still use the PSR-500 and have added an SDS-100 to my arsenal. I found a ton of unpleasant issues with the TRX and wrote a review on it. While I recognize that we each have our own needs and have different listening environments, I couldn't make the TRX work for me.
I suspect the reason you want a TRX over a PSR is to get Phase II capability. Phase II means a trunked system. These days trunked systems are becoming more and more of the Simulcast type. That's yet another issue that the TRX simply was not designed to handle. Unfortunately, as I write this, the 2 SDS models are the only scanners that do handle Simulcast. Roaming and controlling site selection is just one more "little" thing. Good luck.
wwhitby
Autauga County, Alabama
I went from a PSR-500 to a TRX-1. I agree with gmclam that the TRX-1 was "decontented" from the PSR-500 series - some of the useful features were removed. But, my PSR-500 didn't pick up Phase II and that is what new users on the local system are going to. I also didn't care for the interface of the SDS series.
When I put all the control channels into the site list of one scan list, I found I was missing a lot of traffic. Now, I put each site into its own scanlist and "manually roam" by selecting a new scanlist when I'm in range of a site.
hiegtx
Dallas, TX
That 'roaming' ability of the PSR500 & PSR600 scanners (as well as their related Whistler & RadioShack labeled versions) was very useful on systems where more than one site of a given system was in range. It was a disappointment that this did not carry over to subsequent models.
tvengr
Well Known Member
Has anyone tried setting the high and low thresholds to 99% to see if the newer Whistler scanners will scan multiple sites?
