PSR-600/WS1065 same AC power supply?
Progline
Central Washington State
I need to get a replacement power pack for my GRE PSR600... does anyone know if it's the same power connector/ specs as the powerpack that Whistler sells for the nearly-identical WS1065? It uses a rather large diameter coaxial connector with a thin center pin.
Thanks in advance,
Rob
dispatch235
Central Missouri
Yes, the Whistler power supply will work with the PSR600 as well as the Radio Shack Pro 197/652 series. Don't be alarmed when you get it because physically it is much smaller than the original, the newer power supplies are different design.
