psr-600c
baboon53315
Oshawa,Ontario Canada
hi guys.two questions.first...is there a short cut to turn on and off the the different banks i'm scanning?i'm current using scanlite & arc500 for software.i can sort of program with scanlite but can't figure out the arc500 for conv. or trunk.any advice or tips?thanks.
torontokris
Toronto Canada
The only way is to make them different "scanlists" (no more banks).
With the GRE 600 you can make 20 different "scanlists"...
Note programming this is done on the TG object side (you give the talkgroups a scanlist number)... not on the trunk frequencies side. That way you can give 2 TG in the same system a different scanlist number
so 1-10 you just hit the number (5 etc)
11-20 you hit FUNC then the number (FUNC 5 for 15)
