PSR 800 Audio, Mono or Stereo
command_z
Noob Question:
Does the PSR 800 emit sound in Stereo or Mono our of the earphone jack?
Ed_Seedhouse
Victoria B.C. Canada
The jack is a stereo jack but the output on both channels is the same, i.e. mono.
If you plug in stereo headphones you will hear the sound in the middle of your head as the output from each transducer is identical (or at least as identical as the drivers allow).
jackj
NW Ohio
Ed's right. I think the reason they used a stereo jack is because it's impossible to buy a mono earphone today. Everything is stereo and a stereo plug in a mono jack can cause problems.
jaspence
Michigan
It also makes it easier to listen with normal stereo earbuds and not draw attention to yourself in crowded places.
