Easy to Move
I am not as knowledgable about the interworkings of said radio, but I have read about how flimsy this part of the radio is and how it can go south.
I would agree on a point made, that it starts out with a mechanical failure which leads into an electrical. I even thought someone at GRE mentioned a short eventually happens, but I could be very wrong on this.
Sometimes, I am like a radio junkie when my main squeeze has had to go to CA. LMAO.
Hopefully, changes will be made in this design. If you were able to bypass the regular wiring, thus making it more flexible with the soft wire, why can't GRE? I truly don't understand why this modification could not be made at GRE when repairs were made. I would even pay to have this fixed right!
But, the PSR 800 seems to have the same BNC plague based on what has been written.
IMHO,
the BNC is far from the issue,
i had to do my own repair,to my 106
the problem lies in the anchoring of the BNC
to the radio,
its held in place by a 1-1.5mm thick metal(a poor grade-soft makeup)
material.
secondly,that metal is directly anchored to the PCB when it should be
attached at the chassis..
the rigid connection from the BNC to the board becomes stressed,due to
the flex that occurs,as a result of the poor design of the 3 piece radio case,
front-back and top/knob plate.
the back and top should be made from 1 piece,maybe a a die cast metal,charge an extre 15 bucks
and make the radio more rugged,,
i fixed mine,i cut the metal shielding ,then ran a wire from the BNC center pin to the pcb,so now if theres flex,the soft wire provides me with all the leeway needed..
