PSR 800 Default V-Scanner
radionut44
Kernersville, NC
Is there a way to change which V-Scanner folder is the power-up DEFAULT from the radio itself, without the PC? I will be making a trip without the PC and want to be able to change the default V-Scanner during the trip so I won't have to select a different V-Scanner everytime I turn the radio on. I know the default can be set using the PC software, but I want to change it in the field (as I could do with the PSR 500) which remembered the last V-Scanner loaded.
woodsoj
Bradenton, FL
Mine boots to which ever v-scanner it was on when I turned it off. Haven't used default since the first week.
