PSR-800 Delete Object In Scan List
jake01
Painesville, Ohio
I hope someone can help me. I want to delete a OBJECT in a scan list , but not the scan list. How do I do it. Thank You for your time
cookmaster
Tucson,Arizona
Deleting an object from the Scanlist
Click on the copy fromScanner/SD card ,and when it's done up loading to your Computer find the object and delete it,and then click on copy configuration to scanner memory/SD card,the Computer will down load all your stuff back on to your PSR-800,hope that help!!!
from radio
menu
browse objects,press SEL
go to the thing you want to delete
menu
up arrow once
delete object
SEL
done !
hit menu
scan
SEL
to resume scanning!
P.S you could also just stop on that object and SKIP it/
fix computer
Thank You, But after I down loaded to computer I can't read it on the computer.
make sure you have the scanner OFF
plug in USB cable to computer
open GRE program
you may have to point the computer to the correct SD card.
if you dont it will say cant find scanner.
jake01
Painesville, Ohio
menu
menu
up arrow once
delete object
SEL
done !
hit menu
scan
SEL
to resume scanning!
Thank You Very Much for the help I appreciate your time
