PSR-800 EZ Scan: Will it receive P25 phase 2?
jacon12
macon, ga.
Will the 800 receive and decode a Harris P25 Phase 2 system with the latest firmware upgrade available on this website?
Thanks,
Jarrell
KD4YGG
Thanks,
Jarrell
It should.
Confirm the following is set correctly:
- Select TRUNKED RADIO SYSTEMS tab
- Select the system of interest
- Select SITE DETAILS tab
- Select SITE OPTIONS and make sure TRUNKING TABLES are set to AUTO FILL
The Central Georgia system has a non-standard trunking table.
The Macon city system is X2-TDMA flavor.
N8IAA
Fortunately, GA
Thanks,
Jarrell
Are you asking about the Macon City system, or the Central Georgia Interop system?
If Macon City, it is still Phase I. There are NO X2-TDMA TGID's. They are 'D'igital.
If you are asking about the Central Georgia system, you will need to program all of the red frequencies.
Both systems need to be P-25 Auto.
You will need firmware 1.8 to hear any Phase II/X2-TDMA transmissions.
Check the GA state forum for more info about the systems.
Larry
KD4YGG
Here are logs from a 03-May-2015 trip through the area...
CENTRAL GEORGIA INTEROP System
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 00A
System Name : CGIRRS
WACN : 92589
Tower Number (Decimal): 10-10
Tower Number (Hex) : T0A0A
Tower Description : Macon
Control Capabilities : Data,Voice,Registration
Flavor : Phase 2
Call Sign(s) :
Timestamp : Sun May 3 13:04:02 2015
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,854.00000,0.01250,-45.00000,"Confirmed",0.01250,1
08,854.00000,0.01250,-45.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0005","a",854.06250,"00-0005",809.06250,0,0
"00-0057","a",854.71250,"00-0057",809.71250,0,0
"00-0099","a",855.23750,"00-0099",810.23750,0,0
"00-0119","c",855.48750,"00-0119",810.48750,0,0
"00-0127","a",855.58750,"00-0127",810.58750,1,0
"00-0151","a",855.88750,"00-0151",810.88750,0,0
"00-0159","a",855.98750,"00-0159",810.98750,0,0
"00-0179","a",856.23750,"00-0179",811.23750,0,0
"00-0181","av",856.26250,"00-0181",811.26250,0,1
"00-0207","av",856.58750,"00-0207",811.58750,1,1
"00-0239","a",856.98750,"00-0239",811.98750,1,0
CITY OF MACON System
FileVersion:8
-TowerInfo
System ID : 1B6
System Name : Macon
WACN : BEE00
Tower Number (Decimal): 2-2
Tower Number (Hex) : T0202
Control Capabilities : Voice,Registration
Flavor : X2
Call Sign(s) :
Timestamp : Sat May 2 11:44:37 2015
-Tables
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
-Frequencies
"00-0625","a",854.91250,"00-0625",809.91250,0,0
"00-0637","a",854.98750,"00-0637",809.98750,0,0
"00-0673","a",855.21250,"00-0673",0.00000,1,0
"00-0877","c",856.48750,"00-0877",811.48750,1,0
jacon12
macon, ga.
Larry
Thank you for all the replies. Yes, I'm mainly interested in the Central Georgia Interoperable Radio System. Can I do all that you say I need to do within the EZ scan software? I have:
uPAppl ver: U1.9,
DSP app ver: 1.3,
Dsp voc ver: 1.6 and
RR Lib ver: 413
Jarrell
N8IAA
Fortunately, GA
uPAppl ver: U1.9,
DSP app ver: 1.3,
RR Lib ver: 413
Jarrell
You have what you need. Don't know about the library, because I find any reason to update every week. Just make sure that you make a scanlist just for that system. Make sure that it says P-25 Auto. Also, make sure that all the frequencies are included in the system frequencies. If you have problems, PM me.
Larry
jacon12
macon, ga.
Larry
Thank you, Larry. I'll give it a try this weekend after I get the honey do list done. The only question I have right now is about making sure " that all the frequencies are included in the system frequencies."
I appreciate your help!
Jarrell
